1 - 4 of 4 Posts
Preparing to install a new Fuel Valve / Petcock on my W650, the old fuel line broke off. Trying to determine the best way to access the bottom of the line where it attaches to the carbs. Tank is off, in the process of removing the left side Air Box to try to access the fuel line, not sure if it is going to allow me access. I really don't want to remove a carb or carbs to replace a fuel line...any suggestions? Thanks! Weather is beautiful in sunny Tucson Az, want to get on my W650 again!
I usually find the amount of time spent trying to save removing a component to gain access ends up taking longer with the likelihood of breaking something.
The Carbs are easy to remove on the W650 tbh you would probably get to the pipe if you just slide them out slightly maybe leaving the Cables attached.
1 - 4 of 4 Posts
