1 - 4 of 4 Posts
How hard is the clutch the rebuild. I just got it back from the shop and they said the clutch is slipping bad. I adjusted it and it did not help. I would like to get a new clutch or replace the springs, friction disk and shim packs. Whats the best option.
The clutch isn't hard at all to replace/ rebuild. If you have some VERY basic mechanic'n skills you can handle it. I'd recommend purchasing a service manual, because it will walk you through pulling the stuff you have to to get to the clutches, checking all of the specs, and replacing what's necessary
1 - 4 of 4 Posts
