1 - 2 of 2 Posts
I'm having trouble reinstalling the fuel tank on my 2002 Kawasaki KZ1000 Police. There are four hose connections on the bottom of the fuel tank and I'm not sure were they all go. There are two on the petcock, one on the fuel gauge and one is the vent. I know that the vent hose just goes to the bottom of the bike. Not sure where the other hoses go on the carburetors.
Fuel Gauge hose is for draining any fuel that may leak from the gauge gasket and routes down similar to the Tank drain hose.
Petcock has 2 hoses:-
1) Is the Vacuum hose (Blue Arrows)
2) Is the Fuel delivery hose ( Red Arrow)
Attached a diagram for these 2 Hoses.
Vacuum hose is usually the smaller dia hose as it only need a small volume of air to open the Tap, The hose attaches to the second carb in from the left hand side front edge (It should be the only carb that doesn't have a Black bung fitted to the takeoff)
Fuel Hose connect at the lower joint between second and third carb as shown in the picture.
Hope this helps.
1 - 2 of 2 Posts
