1 - 2 of 2 Posts
I'm in the process of changing brake pads on my 3010 and for some reason I can't get the drums back on. I had to use a puller to pull the hub from the axle. I threaded 2 lug nuts on the studs and used a wheel puller to remove them. They were really tight. Hubs had a buildup of stuff on them so I had a machine shop remove the stuff and get the hubs to spec. It appears I have enough space to clear the pads, but the hub will only go on about an 1/8". I don't want to beat it on. Anybody had this issue before?
FYI. I had the same problem just to figure out the front and rear pads are slightly different. You have the wrong pad if you purchased a set, swap them around. The read ones have a square hold in them, The front ones do not.
1 - 2 of 2 Posts
