I have a 2002 Prairie that has been giving me a fit on the carb for the past few months. I cleaned the carbs multiple time thought I had missed something.........Got aggravated and took it to the stealer. He rebuilt carb and same thing. Runs rough above idle cant get it to dial in to run as it should. Got it to where it idles ok, just will not run consitantly above idle.
Also gas still leaks from the overflow from bottom of crab. I have replaced diaphram as well.
Stealer says the problem is the valve seat that is not replacable. Has anyone found a work around for this issue?
I have looked and a new carb is in the 350 ish range. I hate to try to buy a used one only to be in same boat.
I read in one thread about changing brands of carbs to a mikuni. Which ones are interchangable and will work? and where may I find such an animal.
I am a long time lurker here and thanks for everyones help in advance.
