You bought a bike and don't know the specs for it? :shock:
Engine Configuration Inline Four, 4-Stroke, DOHC
Engine Displacement 599 cc
Engine Cooling System Liquid
Compression Ratio 12.8:1
Combustion Chamber Design Pentroof
Valves Per Cylinder 4
Intake Valves Per Cylinder 2
Exhaust Valves Per Cylinder 2
Bore x Stroke 66.0 x 43.8 mm
Claimed Peak Horsepower 109 bhp @ 12,000 rpm
Claimed Peak Torque 48.5 lbs. - ft. @ 10,000 rpm
Measured Peak Horsepower 94.4 bhp @ 12,400 rpm
Measured Peak Torque 41.8 lbs. - ft. @ 10,400 rpm
Measured Power To Weight Ratio 4.70 pounds per horsepower
Engine Redline 14,000 rpm
Valve Angle (Included) 12 degrees intake, 13 degrees exhaust (25 degrees)
Combustion Chamber Volume 10.2 cc
Valve Train Type DOHC, Link-plate Chain Drive,
Bucket Followers, Shim-under-bucket
Lash Adjustment
Valve Adjustment Interval 7500 miles
Intake Valve Diameter 27.0 mm
Exhaust Valve Diameter 22.6 mm
Intake Valve Stem Diameter 4.0 mm
Exhaust Valve Stem Diameter 4.0 mm
Intake Valve Maximum Lift 9.2 mm
Exhaust Valve Maximum Lift 8.4 mm
Intake Valve Timing
Open BTDC 56 degrees
Close ABDC 80 degrees
Duration 316 degrees
Exhaust Valve Timing
Open BBDC 61 degrees
Close ATDC 33 degrees
Duration 274 degrees
Valve Timing Measuring Point 1.0 mm.
Fuel Delivery System (4) Mikuni BDSR36R CV
Carburetor Venturi Size 36 mm
Air Filter Type Dual-element Foam
Exhaust System Type 4-2-1
Ignition System Digital Electronic
Lubrication System Wet Sump
Oil Capacity 3.7 quarts (3.5 liters)
Fuel Capacity 4.8 gallons (18 liters)
Transmission Type 6-speed, Constant Mesh
Clutch Type Multi-plate, Wet
Clutch Actuation System Cable
Clutch Spring Type Coil
Number Of Clutch Springs 4
Number of Clutch Plates 17
Drive Plates 8
Driven Plates 9
Primary Drive Gear
Primary Drive Gear Teeth (Ratio) 44/ 89 (2.023:1)
Final Drive Sprocket Teeth (Ratio) 15/ 40 (2.667:1)
Transmission Gear Teeth (Ratios)
6th 26/ 24 (1.083:1)
5th 28/ 23 (1.217:1)
4th 29/ 21 (1.380:1)
3rd 31/ 19 (1.631:1)
2nd 33/ 16 (2.062:1)
1st 38/ 13 (2.823:1)
Transmission Overall Ratios
6th 5.843:1
5th 6.566:1
4th 7.446:1
3rd 8.800:1
2nd 11.125:1
1st 15.231:1
bill said:
LOOKING FOR SPECS ON MY ZX6R. TOP SPEED, PART, HIGH PER PARTS AND ACC. ANY INFO OR WEB SITES WOULD BE GREAT!!!
TKS
