1 - 2 of 2 Posts
I have a 2003 650 prarie that will not start. The engine will turn over and there is spark. There is gas to the shut off. tried draining the gas from the carb, new plugs, putting gas in the carb. Also tried starting with the choke on and off. All it will do is turn over. This problem occured after being ridden all winter without a problem. Last time it someone rode it, it was parked and turned off overnight. The next day it would not start. Does anyone have any suggestions.
A good place to start is with a compression test if it just quit out of the blue. Refer to your service manual and follow the instructions for testing compression, as the decompression system has to be defeated to properly test the compression on these engines.
Also, check the roll over sensor to be sure it has not been triggered from tipping the ATV on its side for some reason, or that the connectors shook loose.
1 - 2 of 2 Posts
