The guys covered 2 of the 3 recalls. The third one was the fuse for the cooling fan. You'll want to be sure that's been taken care of too. The original fuse was a 10A and the recall fuse is 15A.
I haven't had the oil filter recall done yet and I don't think I will. No one at Kawasaki has convinced me that it's serious enough to give up the convenience of a spin on filter!! Supposedly on a cold start there can be enough oil pressure to deform the base of the oil filter before the pressure relief valve opens. Someone told me that if you were running straight 50w oil, it was freezing cold out, and as soon as the engine started you opened the trottle wide open it might happen. I figure it's about as likely as the bike just starting on fire, so I'm going to let that one go.
I'm getting the muffler bracket fix done next week.
