2006 gas mule 3010 was left setting for 3 months, and was used dailly to that point. It started up but ran rough with smoke. Flooding
pulled carb and put in kit and cleaned with carb cleaner. same problem
pulled and cleaned carb again. same problem. I can remove fuel supply line while running and runs fine for few seconds then dies. reattach fuel line and restart and pinch off fuel line with thumb and finger and runs fine when sweet pinch is found. I can pinch line to the point of starving out and engine dies.
bought new float with another new needle and relay based on advice of local guy. removed and cleaned carb again and added new float and new neddle. replaced relay with new one and new head gasket. same problem.
Also I have pulled plugs after running it for a few and they are black and damp but not fouled. replaced and engine ran fine with fuel line pinch.
my skill level is low and i am tapped out any help would be appreciated.
