Video worked fine. ATV's are not really my area of expertise. The guy who can probably really help is a member called cookiemonster. He drops by maybe once a week or so.
The float valve seat is essential to stopping the flow of fuel into the float bowl. Drilling it out like that makes no sense at all as it destroys the sealing surface. Possibly the former owner thought he could "clean up" a damaged seat surface with a drill bit and accidentally drilled all the way through. In any event, you have replaced the seat so that is no longer a concern as long as the valve now operates correctly. Have you tried to test float height with a clear tube on the outside of the carb? The tube, if attached to the float bowl drain will given you the exact real level of fuel inside the carb.
Does your ATV have a "Limp Home Mode"? Perhaps that is the cause of your problem.
