1 - 7 of 7 Posts
My mule when I turn the key sends no power to anything. This has happened twice. I have replaced the battery and know it has the 12 volts needed. Last night after hunting it did it to me again. I hooked my jump box to the starter and turned the key to the start position and it cranked but there was no power to my lights or fuel gauge. When I got back to camp I turned the key to the off position and it shut off. I am thinking the key switch is bad and not allowing power to go to the accessories and starter. I have ordered a new switch. Am I looking in the right direction?
Found the problem today and it was a bad ground. This is after I had checked every wire and fuse. Looking at it I decided to unhook the ground from the frame to the battery. As I loosened it everything started working. So cleaned up the ground and everything is working now. Thanks for all the help.
1 - 7 of 7 Posts
