looking for a engine oil filter make and part number other than Fram, the problem with Fram is the threading comes out instead of in like your belly button, which makes it too tight of fit to screw on unless you indent the other end with a socket in a vise about 1/8" then it fits up no problem but when you go to remove,.. with the heat and pressure of the oil it pushes the indent out
Does anyone know if a Kraulinator filter or other breed is a better fit.??
Thanks
KOBOSS
Thanks
KOBOSS
