Finally got it running. The wrong looking fuel pump actually works. It has the pump relay missing. I hooked it up to 12 volts and it ran. Doesn't the float keep it from over filling? Does the relay control the pump in any way? I can get it to idle a little on the fast side for right now. The exhaust pipes glow red. I believe that is a lean condition???? What would cause and what would cure that? awaiting some Guidance thanks
Discussion Starter #3
I hot wired the fuel pump and ran it with the line pinched for about 2 minutes. It never stopped running. That's a bad sign isn't it?
