1 - 1 of 1 Posts
The manual for 3010 differs from 3010 Trans in the assembly description for the driven pulley, when assembling the movable sheave onto the ramp.
The non-Trans 3010 manual states (Converter System 5-19) "Install the adapter and tighten the flange nut until the ramp halfway, turn the movable sheave clockwise 120 degrees and hold it".
The Trans 3010 manual states (Converter System 6-21) "Install the adapter [C] and tighten the flange nut until the ramp halfway, turn the movable sheave counterclockwise 120 degrees and hold it".
One will tend to tighten (wind) the spring, while the other will tend to loosen (unwind) the spring.
Which is the correct instruction? Alternatively, which direction should the movable sheave be rotated 120 degrees?
The two driven pulley assemblies appear identical.
Thanks in advance.
1 - 1 of 1 Posts
