Just burn the cheap stuff (if there is any anymore) an you'll be fine.Shakli said:What gas are you using? I just purchased an 02 Vulcan 500 used. Someone told me it has a high performance engine so I should use premium gas. Is this correct?
I think he has ants on his keyboard! :smile:woodchucks800 said:RB is your new avatar a pic of you figuring out how to add a pic to your post?(LOL)
The owner's manual says to use premium which I do, is regular unleaded really ok to use in this bike (800A)?woodchucks800 said:Just burn the cheap stuff (if there is any anymore) an you'll be fine.
Doc , Regular is all you should be putting in your 800, the 800 has a problem with carbon build-up. The cheaper fuel burns hotter which helps with keeping the carbon build-up to a mininum. You can also add some seafoam to the gas about every 4th tank , along with going out an running the bike up to the rev limiter every now an then(thats the fun part) :grin:Doc2003Cobra said:The owner's manual says to use premium which I do, is regular unleaded really ok to use in this bike (800A)?
Does this bike have a rev limiter? Also if I use regular do I have to worry about overheating, I live in Arizona and a couple of months it will be very hot here.woodchucks800 said:Doc , Regular is all you should be putting in your 800, the 800 has a problem with carbon build-up. The cheaper fuel burns hotter which helps with keeping the carbon build-up to a mininum. You can also add some seafoam to the gas about every 4th tank , along with going out an running the bike up to the rev limiter every now an then(thats the fun part) :grin:
Doc2003Cobra said:Does this bike have a rev limiter? Also if I use regular do I have to worry about overheating, I live in Arizona and a couple of months it will be very hot here.
I have a 2003 800A, my owner's manual says to use unleaded with minimum antiknock index of 87. But has a caution: If engine "knocking" or "pinging" occurs, use a different brand of gas or a higher octane rating. The Clymer manual simply states to use regular unleaded. I have tried premium (1 tank full) I think the bike runs better on regular.Doc2003Cobra said:The owner's manual says to use premium which I do, is regular unleaded really ok to use in this bike (800A)?
Yeah, that's why I stuck it there. I'm trying to figure out how to animate it so the poor bassturd is smashing his head on the keyboard :smile:woodchucks800 said:RB is your new avatar a pic of you figuring out how to add a pic to your post?(LOL)
