After nearly 2 months of riding, I've finally hit the 500 mile mark on my
'04 Ninja 250. I'll call my dealer this week and make an appointment for the 500 mile service.
When I purchased my motorcycle, I was told that this service would cost about $180. My question for everyone here.....
what should I expect to get for my money?
The manual says this service should include:
=Carb Synchronization
=Idle speed check
=Throttle Play adjust
=Valve Clearance Check
=Air cleaner - clean
=Brake fluid check
=Clutch adjustment
=Oil & Filter change
=Adjust & lube chain
=Tighten nuts,bolts,fasteners
I'd say $180 is a fair price to pay for ALL of this.
Other questions...
Is partial disassembly of the engine required to check valve clearance, or is it possible for them to somehow check this electronically (by checking valve timing???)>?
If valve adjustment is required, would it be fair to expect an additional charge for this service (or is that a PART of the valve clearance check)?
Thanks!!
=Idle speed check
=Brake fluid check
=Clutch adjustment
Other questions...
Thanks!!
