I'm looking at the owner's manual, the following is what is scheduled for 7,500 miles:
Carburetor Synchronization -check *
Idle Speed Check *
Throttle Grip Play -check *
Spark Plug -clean and gap *
Valve Clearance -check *
Air Suction Valve -check *
Air Cleaner Element -clean
Evaporative Emmision Control System (C) -check *
Battery Electrolyte level -check *
Brake Hose, Connections -check *
Brake Light Switch -check *
Brake Pad Wear -check * #
Brake Fluid Level -check *
Fuel Hose Connections -check * K
Clutch -adjust
Steering Play -check * K
Drive Chain Wear -check * #
Nuts, Bolts, and Fasteners -check *
Tire Wear -check *
Engine Oil -change
Oil Filter -replace
General Lubrication -perform
Swingarm pivot, uni-trak linkage -lubricate K
Radiator Hoses, connectors -check *
* Replace, Add, Adjust, or Torque if necessary
(C) California Model only
K Should be serviced by an authorized Kawasaki dealer
That is an intimidating list. What can I do myself? Where can I find out what/where this stuff is? What do I check for?
I'd like to do as much as I can myself.
Idle Speed Check *
Clutch -adjust
Tire Wear -check *
Engine Oil -change
Oil Filter -replace
