Coils will trick you. They tend to fail when hot or under load. Have you checked the vent on the fuel tank? Could be running out of fuel.Thank you I tested the ignition coil with an ohmmeter and it seems like it’s OK got the proper readings but I did notice it’s leaking fluid from The coil. I think it might be breaking down when he gets hot.
