zx7r New replacement clutch slips, bike goes nowhere!
According to the factory manual for the zx750p2, when replacing all plates the manual recommends 6 X 2.3mm steel plates and one 2.0mm,2.3mm,or 2.6mm plate. Then a free play measurement must be performed. Even though in the first section it recommends only the 2.0mm OR the 2.6mm, later it does state that it may be necessary to use a 2.3mm thickness for the seventh plate. This procedure is only used when replacing all friction plates.
So I had a free play measurement of .17mm with the seventh steel plate being 2.6mm, which is in tolerance with the usable range between .05mm -.35mm. However I noticed when tightening and torquing the spring plate, that the clutch would simply slip, making it impossible to torque without jamming the output sprocket.
Having started the motorcycle when selecting first gear the bike would shudder, then immediately was followed by a lesser shudder. So it felt as though the gear was engaged momentarily, but then the clutch would slip and give way. When letting the clutch out after putting the transmission in first gear, nothing happened, not even a vibration could be felt.
After fuming about it all night I have come up with two possible solutions to why this can happen. First, since the last friction plate on the stack is seated in an offset channel to the rest of the stack, it is possible that the 14 total plates do not go any further than this channel for the last friction plate. This would cause the spring plate to simply be pressing against the last friction plate, which in turn is completely seated in it's corresponding channel in the basket. So the spring plate is pressing on the friction plate which is only pressing on the basket, leaving space between the remaining 14 steel and friction plates.
The second, which is less probable than the first solution, is that the inner hub/cam is jammed or not properly seated.
One thing I am sure about is that the hydraulics used to disengage the clutch will have nothing to do with it slipping since there is an obvious non-equilibrium between the hydraulics and the mechanics of the clutch system. To test this, I removed the slave cylinder and I could still rotate the spring plate by hand while the transmission was in first gear.
I will know by tommorow what the problem was and share my findings with, since I know how frustrating this problem is.
