1 - 2 of 2 Posts
I had to replace the converter belt on my 750 Teryx. Just finished getting it back together and when I drove it up the road the Speedometer didn’t work. It was on, showing 0 mph.
On the converter side I had an extra wire that wasn’t hooked up and I can’t find anywhere it could plug up. It is wire tied to the wire that plugs up at the bottom of the engine just below the converter cover.
The loose wire appears to go toward the fuel tank so it seems with a wire tie holding it to the wires that plugs up on the lower right side as mentioned earlier.
Thanks for your help/advice.
1 - 2 of 2 Posts
