1 - 2 of 2 Posts
This space for rent
I have 750 fours and twins, and the only way you can fit a 750 twin motor in a 750 four frame, is to increase the distance between the lower and upper frame tubes by 2". The 750 twin is quite a bit taller than the 750 four, and the mounts don't line up either.
Yes I actually did try to set a 750 twin motor in a 750 four frame :)
Why not put a 650/750/1000 four cylinder in it?
1 - 2 of 2 Posts
