"Ive got a 78 KZ1000 LTD with stock Mikunii carbs and i need to know how many turns the air screw should be turned out. Ive heard 2 or 3. Can someone tell me the best place to start, thanks Keith
The Cruising Gunsmith
I gently screw them in until they stop and back them out about 2 turns as a starting point. It is usually happier if it's a little rich than if it's too lean.
Once the bike is fully warmed up, turn them in until you hear the idle RPM drop off and then back them out about 1/2 to 3/4 turn or so.
