i just got a 78 kz1000 ltd. its not stock. electrictronic ignition, accel coils, taylor wires, port and polish work, big bore kit, jardine header and muffler, black diamond stainless steel vavles, aftermarket clutches(the back of the manual says vaspro clutches, but couldnt find them online.) the wiring is hacked up (i need a good wiring diagram) it runs. it is now idling up to about 3500 and will sometimes drop to idle (1000). before it idled high for a lil bit then dropped. the exhaust did leak. fixed it. the number 1 intake leaked so i siliconed it. i sprayed the intakes and found no leaks. i have carbs off now cleaning them. they need adjusted bad. plus second gear is out. i cant get the rear brake pedal on. the spring is a bear. if anyone can help i will be greatfull
