The rear shock on my 800a is hidden and very hard to adjust. The only method I know of to adjust the preload on the shock (short of taking the rear end of the bike apart) is to use a steel rod and sledge hammer to knock the adjusting collar around to the desired setting. I was considering installing an air shock so I could adjust it externally. Has anyone done this on an 800a? Where did you get the shock? Are air shocks really any good? Is there another solution?
Thanks,
Derek
Thanks,
Derek
