I had a head gasket installed this summer because I had a small leak on the right side I get it back and I have a small leak on the left side should the bolts be torqued or alternated when tightened also which is the right size and how many head bolts are there.Thanks Steve
Too late....
it is already snowing there and cold. First thing you need to do is buy a manual for your bike. They are often on ebay reasonable. You can tell how many headbolts you have by removing the tank and looking......Your oil leak is most likely from the endcaps, gasket, or the bolts on the end of the cam cover were not thread sealed.....chrisd3
