I recenty bought 2 beat up 1982 KZ440's. Both are in bad shape but I've got enough parts between the two of 'em to get one running bike. I only have one set of carbs. One carb looks great and the float was free and clean. But the other carb was stuck so bad, it took an hour and a lot of heavy duty tools and fluids to get it unstuck. Now I've got the carbs on one of the bikes and I finally got it started but the bike backfires REAL bad. The backfiring is coming from the back of the carbs through the airbox, not the exhaust.
I've got a few contributing factors that may be causing the backfire...
- The carbs were completely taken apart (every screw) and cleaned out, but I probably did not leave the screws in the same position as before.
- I don't have the air filter in the air box, I'm using a piece of foam to cover the back of the air box.
- I have not tightened the brackets very tight on the boots connecting the carbs to the motor. (I have felt and seen bursts of white smoke escaping this connection when backfiring)
- I have nothing to tighten the connecting boots between the air box and the back of the carbs. Do I need to?
- I don't have the gas tank connected, I'm simply pouring gas into a funnel connected to the main fuel line into the T-valve between the carbs.
- I had to spray WD-40 into the valves to free up the pistons to get the motor to turn completely. (But, I've had the bike running for over 10 minutes... the WD-40 should be burned off by now)
Given all of these conditions, what do you guys think I need to adjust to help with the backfiring? I'd like to leave the carbs in there, but if I need to pull 'em out to fix this problem, I certainly will. A friend of mine recommended adjustments to the timing chain, but I really doubt anything is wrong with that if all I've really had to work on is the carbs. Let me know what you guys think. Thank you!
PS: Do you guys think it will help if I post a YouTube vid of the bike running so you can see what it looks and sounds like??
