No power and buzzing/vibration from the junction box.
My riding season here in New England is quickly drawing to a close, now this...
After sitting in the garage for two years I decided it was time to fire up the old Ninja and get her back on the road.
Changed all the fluids, filled the tires, put the battery in and cranked right over - no problem. Took a little ride around and everything seemed to be working well.
THE PROBLEM
Two weeks later I decided to change the spark plugs.
Changed the plugs, turn the key to "on" (everything that should light up does), hit the starter and "click" - nothing, no power either.
Key off, check everything over including the plug wires, turn the key to on. No power and a loud buzzing plus vibtration from the junction box.
The battery is fine, then drops when the key is on.
I can't pinpoint the buzzing within the junction box, but pulling the main relay stops everything.
Any ideas on how to fix/troubleshoot this thing would be GREATLY appreciated.
Thanks.
HK
THE PROBLEM
Thanks.
HK
