1 - 1 of 1 Posts
My EN450 has been acting up all season and now is almost unrideable. Started out as left cylinder would bog down in mid throttle range. Adjust valves, checked carbs, played with needle height and main jet size a little. Seemed to get a little better than worse again. Checked floats for stuck/height, all good. Changed jets and needle heights back to last known working set up (had it fine for 2 yrs), now it wont even idle properly. Left cylinder misses about every 3rd cycle.
Ohm tested ICU and coils, both in ranges. Any ideas?
1 - 1 of 1 Posts
