1 - 4 of 4 Posts
86 Ninja 1000R-Was running fine, started missing out at all speeds, white smoke from the pipe. Has spark to all cyclinders, Fuel to all cyclinders, took resistance on coils-measured fine, took measurements on pickup coils-475 and 510 Ohms, changed plugs, after running it for about 5 minutes pulled plugs, #2 plug was not firing and #2-3 has risidual oil on them. When i first bought the bike about a year ago i changed the oil out to a semi synthetic. Any suggestion?
Gotta love the zx10
Check for gasket leaks.. You say it is pushing out white smoke? Check your radiator fluid and reserve tank. You could be leakin some fluid in the cylinder. Do you smell anything when it is running?
I will do a compression check on it...yes it has an odor to it but I can't cant identify it..does not smell like antifreeze, oil is clean...thx
Gotta love the zx10
Compression check would be key. It might need new piston rings but you will determin that after the compression test
1 - 4 of 4 Posts
