I bought a rebuid kit for the fuel tap and made the rookie mistake of not paying attention to the disassembely. Now I cant get the diaghram mounted back in the same way. There is a small vent like hole drilled on the plate between the two diaghrams and I have no idea which way it sits on the back side of the petcock plate. It actually leaks gas right now. So much for a rebuild.
Any one know of a diagram that shows howt to reassemble.
kawasaki parts doesn't show enough detail and neither Clymer nor Haynes show it either
Thanks in advance
If no one else has an idea, my favorite thing to do is to look at all the old parts and try and figure the oder of assembly. Wear marks and dirtys spots have a way of letting you know what went where..... If this doesn't help sorry
The side with the o-ring goes to the bigger side metal piece on the petcock assembly. The idea is to keep the vacuum side (small connection point, on smaller piece of metal) clear of gas and to open/close the gas connection. Hope this helped ya.
