1 - 9 of 9 Posts
My preference is for Galfer. As long as you are upgrading if you haven't put stainless steel brake lines in you may want to consider them. Great updgrade at about $170.00 for both front and rear or you could just do the front brakes since that is what you use the most. The rear is more cosmetic due to the frequency of use.
well since i dont have a rear disk there is noo need :D .. can you actually feel a difference with SS break lines??? and what brand lines do you recomend??
Brake lines would be Galfer and Gouldrich. My personal favorites are Galfers. The idea behind stainless steel lines is there is no expansion that you will experience like a regular rubber line and therefore when you squeeze - you actually apply more pressure to the brake due to the line being more rigid.
Yes - you do feel the difference.
well supposibly you cant get Galfer in Canada so im told.. what american web site sells them alot with the SS lines???
1 - 9 of 9 Posts
