1 - 4 of 4 Posts
Have a 07 900 Classic LT has 3k on it. This is the first Vulcan so I am learning more and more about this ride. I have noticed that it has a heavy viberation at and above 65 mph. On my older V-twin rides that is normal. Didn't think that the new ones would viberate this hard. Am I being too critical or is this something I need to check into?
Other than that this is one fine lite weight for around town and even on short runs. I take the Wing on longer rides.
OldIron
So are you talking about engine vibration, front end or what? On mine before the Scootworks pulley I had to be at 80 +(indicated) before I felt any real vibrations and that was in my feet and it really was not that bad.
The vibration comes from the engine I am thinking. You can fill it in your hands, feet and rearend. It was not vibrating this bad until the shop had to work on it due to a faulty engine housing (had a small oil leak on bottom of engine), they replaced the housing and that is when I really started feeling the vibs.
OldIron
1 - 4 of 4 Posts
