1 - 2 of 2 Posts
Go to Kawasaki.com, follow the parts diagram link, and take a look at the gear change mechanism. You will see an arm with a cable connection socket, that is the transmission side. Look for where it comes out of the case and you will see the bracket for the cable, and the arm.
The lever side is common sense, and the cable may be viewed in the cables diagram.
1 - 2 of 2 Posts
