1 - 6 of 6 Posts
hi guys i got the above bike and even with 2 car batterys in it it still starts hard.its charging fine,any suggestions?
thanks
if you know how to do a couple of tests like a voltage drop you can check your battery cables . if thats not it like elr your starter is probably going. You would do a cranking amp test for the which is done with a piece of equipment you are not likely to have, but if you know anyone that works at a garage tow you atv down to them the could do it easliy enough.
Discussion Starter #6
i hoped it wouldnt be the stsarter,i replaced the brushes last summer.after it is warmed up the bike starts fine,thanks for the replys.
1 - 6 of 6 Posts
