1 - 6 of 6 Posts
I am getting a black oil coming out of my exaust and i do not know why. My spark plug isnt fowling so could it be my jetting? also it has started to make a weird pinging noise and i cant tell were it is coming from. i dont know much about bikes but am trying to learn. so any help would be greatly appreceated. thanks
Dirt Bike Dad
When was the last time you changed your muffler packing? Checked your jetting?
This is normal for your bike. Run 50-1 and race gas and it will stop, though I don't recommend running that lean unless you are just racing it on a track. Definitely repack the muffler and run 40-1.
Discussion Starter #5
I checked the packing and it was soaked so i will change that. i was running it 50:1 but with 87 octane so i changed to 32:1 with 91 octane and it got better but i will try 40:1 and see how that helps. I havent messed with the jetting since i bought the bike a couple months ago so do you think i should check that to. I dont know much about jetting it though.
Jetting is only changed to correct a running problem, ie missing on top end or bogging on low end, black spark plug or clean white, etc. Your fuel/air ratio has nothing to do with the black ooze coming out of your pipe. Change your packing and your bike will thank you.
1 - 6 of 6 Posts
