1 - 4 of 4 Posts
I recently got this bike for me boys. apparenly had about 8 hrs use since rebuild. now i have fired it up all seems ok sound responsive...but then it dies in the *** like its not getting the fuel???. carby has been removed and cleaned, i have checked fly wheel for play and all feels firm. sufficint fuel is flowing into the carb...would it be electrical??...to me it seems ituse up what fuel is in the bowl then runs out...i then wait awhile ..few more kicks away we go...then same again??:
Pull the fuel line off the carby and turn on the fuel seeing if the petcock is not damaged or blocked.
MX. Dad and Racer.
take the carb apart again and be sure to check all the jets .
take it completely apart .
some times you cant see the little peice of dirt blocking the jet.
AZ's Official Mechanic
if its running the bowl empty then the petcock isnt flowing (inside tank or inside petcok) or the needle/floats are not allowing fuel into carb
1 - 4 of 4 Posts
