1 - 2 of 2 Posts
I recently bought a 94 Vulcan 500 with no speedo cable. I bought and installed the new one but it is quite loose and looks like it will rub against the front tire with the slightest vibration. I noticed that there is a small hole on the rear side of the front fender and i'm wondering if there is some sort of bracket or something that should go there to hold the cable in place or if the cable is supposed to be run through the hole. I haven't been able to find and good pics of the front fender so I thought I would ask here. Can you guys help?
AZ's Official Mechanic
you are right in your assumptions. when the old cable was taken off they took that peice too. its a small plastic retainer ring that is attached to the fender and the cable goes thru that. call www.ronayers.com and tell them what you need. they will be able to fix ya up. or go see your dealer and look at the microphice.
good luck :wink:
1 - 2 of 2 Posts
