1 - 5 of 5 Posts
what is the largest tire i can switch to it has the 130 tire now and can i change complete wheel from a few years newer 600 and will it fit?????
Discussion Starter #3
what i have is an late model 94 zx600c with a 130 on it i found a complete rim ft and rear with a 160 on it off of another 94 600 . is there a difference in the frame so it wouldnt fit on the bike ???thanks for any help
if you found a 160 off of a 94 600c then it isn't oem. OEM is 130 rear. I would personally stick with the OEM size, but I think if you check out the sticky for the 600C you will find the answer to your questions. And welcome to the forum. -S
1 - 5 of 5 Posts
