1 - 1 of 1 Posts
ok i went and had the bike carbs done at a shop synched cleaned set ran great for 2 weeks then while driving it it dropped the cylinder revs high like 6k adn will not idle properly talked to the shp that repaired it said probly running to lean with enthenol in gas replaced low speed idle jets from 38 to 40mm.set the low speed idle screws to three turns still revs high and does not idle sprayed for vaccum leaks everywhere no difference.took apart and rechecked for plugging nothing rechecked floats are ok.tried spacers in needles nothing.pulled plugs left side is slightly black and right side is white.checked spark good blue spark not dropping spark the boots are good and wires good.anything i am missing.please let me know you text me to at 518-227-4343 would like to hear a few suggestions.
1 - 1 of 1 Posts
