I have a 95 kx 125 it runs good if your on the gas and riding it hard but when you come to a stop and let it idle for a second it loads right up or even when your down shifting coming down a hill i took it to the kawasaki dealer and they jetted it but still didnt fix the problem I even have the needle valve as lean as it can go.IT smokes alot out the pipe also I run the mix 40:1....can you help??
