1 - 5 of 5 Posts
been a long time away from dirt, my 96kx125 has 3 stubs for hoses on it, the crankcase has 1 3/8 size stub, no hoses, got the bike running after going through carb, oil is blowing from top of crankcase near oil filler, toward carb,,,
two stubs on opposite sides of slide and i know the one on the bottom of float bowl is overflow and should hang below bike. but for the life of me i can't seem to find out what that crankcase one is for, is it a vent?
Thanks TJ
not 4 your crankcase but your transmission,very common VENT on most trans most aps.
Oil out that vent means your trans is pressurizing. Maybe too much oil or leak frm crankcase into trans. or waterpump leak to trans.(less likely/oil will turn thick milky).
Hard to say from here.
1 - 5 of 5 Posts
