I am reaching the end of my rope trying to figure out what is wrong with my 1996 Vulcan 1500 (VN1500). It started 2 weeks ago. I was riding to work and right before I got there I decided to fill up at a Shell station since I was on reserve. Filled up with unleaded 91 octane, drove 1 block to work and parked it. After work, I came out and tried to start it but it began to backfire, act like it was out of gas and die at idle. I manage to limp home keeping it revved high and riding through it's lurching and sputtering.
Then the following weekend I started working on it. I first thought the fuel was the culprit so I drained the tank and got gas from a different station. Didn't make any difference. I then tried replacing the fuel and air filters and the spark plugs which were carbon fouled, (covered with black dry powder). The engine ran a little smoother but still back fired when I revved, and idled . I tried riding it like this around the block and it would run fine then act like I was running out of gas and start to die. Then it would roar back to life and start the same cycle over again.
Last night after letting sit for a few days, I decided to burn the gas out of the lines by switching the petcock/fuel valve to "OFF". That way I could work on the rest of the fuel system, (fuel filter, carb, etc.) this weekend.
I did what I normally would with a cold start and pulled out the choke, opened the throttle and started the engine. After a few seconds, I switched the petcock to "OFF" and pushed in the choke. It seemed like it was idling ok so I let it set until the gas runs out. Not only did it keep running for over 15 minutes, but it idled fine too. I shut it down and now I am totally baffled. Does any one have any ideas what I should try to do next or what components to look at?
One other thing to keep in mind, I bought this bike used this spring and since it seemed to be running fine I've only changed the oil and oil filter, replace the front tire and brakes but have done nothing else to it. Also I don't know if any routine maintenance was been done in the past.
