1 - 2 of 2 Posts
first off i took the swingarm off and make it a full rigid frame i got the bike with no wiring harness got on off ebay put it on cant get spark from the coils checked the red wire going in the coils if a test light i got power check the green wires and have power coming out if thats right. then i got my VOLTMETER and check the number go up then come down to 0.0 i think i am testing them right
If you've checked the plug and plug wires it could be a problem with the coil, igniter, or the pickup/pulsar. Although you will be able to measure voltage at times on the green wire, that is the ground coming from the igniter.
1 - 2 of 2 Posts
