1 - 6 of 6 Posts
So i have this bike that my friend gave me and there is a serious problem with it.. it turns over and it doesn't start..
-i have changed the whole wire harness with a new one
-new computer and igniter..
-new coil packs
-new wires
and there still is no spark?? is there any ideas that you guys could think of as to why this bike can't start???
the bike gets fuel... air.... just no spark?? any ideas? thanks..
i also checked to see if it were in gear and i was trying to turn it over... and yeah it was in "N"
thanks!
Mike
Welcome to the Mad house :rolleyes:
Has the bike still got a Kawasaki OEM Ignition switch fitted ?
Check the grey wire at the Igniter with the Ignition on and make sure your reading a reduced battery voltage...
thanks for the welcome!
but as far as i know... it is the oem switch.... but i do know that the ignition was changed?? lol... so i dunno?
i will try the grey wire thing.. and see...
do carb bikes have one of those tip sensors as well?? you think maybe it might be that??
Na your bike hasn't got a Vehicle Down Sensor..
Let us know what reading you get on the Grey wire..
crank sensor?
battery voltage?
blown ign fuse?
plugs?
Greenis i followed all your posts but Here are the Good news and bad news.
The good news: i know basics of mechanic so if you ask me for ohm, volts, coilst alternator, rectifier regulator etc i will make your explanations easier.
The bad news: English is no my native lenguage so eerytime i try to follow your indications i get stocked in words i dont know.
So plssssssssssssss give me an answer as seem your the the one to help me with this problem.
Thanks in advance :oops:
1 - 6 of 6 Posts
