1 - 9 of 9 Posts
I just bought a KLX 300r and plan to use it for both on and off road riding.
I've looked around and have not seen anything regarding a good tie pressure for riding on pavement. I've seen a lot of 15psi suggestions for off road use, but that seems pretty low to me for riding around 55 ish mph on pavement. The tires I have are not much help either.
Not sure if it matters but I'm new to riding and this is my first bike.
Super Moderator
The tire likely has the info you seek:
Look on the sidewall. Every tire mfr puts there their "max pressure at max load" psi or bar or whatever. It's a light bike, you're likely a light fella (or gal ;)) so I'd take that max pressure and subtract 5 or 8 psi, give it a try and adjust from there. I would, at all costs, completely ignore the owners manual and any stickers on the swingarm (hint, hint). Every mfr states notoriously low pressures for OE tires.
Then I'd look into getting a battery tender installed and stowing on-board some tire repair stuff (tube or tubeless, whatever you got) and a small Slime air compressor. Be prepared! I remember several flats out in the woods or in a sand pit. Not fun pushing all the way back, trust me!
Administrator
I don't know if copywrite would apply to an owner's manual particularly since Kawi no longer has it and if they had it, it would be free anyway. Service manuals are a different story.
Discussion Starter · #9 ·
Google is your friend. Free download. You may have to put Adobe Reader on your phone but then you can take the manual wherever you go. I do this with all my vehicles.
Thanks for the link. The owners manual will be vary useful.
Tire pressure on the manual is recommended 11-14psi for off road riding. Nothing given for pavement, but I'm not surprised. I don't think they intended the bike to go on road back then. I tried 14psi but didn't like how soft it felt. I'm going to play with increasing the pressure a little bit at a time until it feels better on the road and just lower it before going off road.
1 - 9 of 9 Posts
