1 - 4 of 4 Posts
i have put vance and hines exausts on my bike sounds great but back fires a bit when i throttle down .Ive blocked of the two hoses on cylinders which helped a bit now ive been told to take the mixture out 1/2 to 1 turn but i need to know the correct screw cheers for ur help.
I have a 98 VN 1500 Classic with Cobra pipes. The only way I could get it to run good was by re-jetting. If you go to the link I gave you and look up the model you will see a pdf file on the right by the price. This will show a picture of the carb and where the screw is.
Good Luck.
1 - 4 of 4 Posts
