1 - 2 of 2 Posts
Hello All! I have good news, and not so good news. I finally got the carbs put back together after a thorough cleaning and the bike runs alot better, but still will not run without some of the choke on. I have tried to adjust the air fuel mixture screws and beleive that I've got em WAY outta whack. What's the proper intial setting, IIRC it's 1 1/4 turns out, correct?
The Cruising Gunsmith
I would try setting them about 1.5 - 2 turns out from all the way turned in (do that GENTLY) for a starter setting. When you get it running and warmed up, turn them in until the RPM starts to drop off and then back them out about 1/2 to 1 turn from that point.
1 - 2 of 2 Posts
