It will run even better if the intake has ONLY Japanese air also. I see a trip in your future.You mean it will RUN better with Jap air as well as ride smoother? WOW I gotta check out the Jap air. I was told the Austrlian air from done under was pretty good.
The air from which of their Islands though. I want to get maxium effect.It will run even better if the intake has ONLY Japanese air also. I see a trip in your future.
The best way is to ride the bike to Japan. They have special equipment to make sure you get all the bad air out and put in OEM air.How do I ensure I get all my summer air out of my tires? I don't want any old summer air contaminating my fresh winter air.
Why bother? It's already 79% nitrogen... just fill it up, then as it leaks out, add more air.Actually nitrogen is the ticket, stays cool and doesn't leach out as much as atmosphere
We only have two seasons here... summer, and riding season :wink:I can't believe you are still running the summer air, why didn't you switch out for fall air?
I don't have any personal experience with nitrogen in tires but have read that on the track, the pressure doesn't increase from heating like air does. remember that the racers measure their pressures down to .10 psi.Why bother? It's already 79% nitrogen... just fill it up, then as it leaks out, add more air.
After a few cycles, all of the oxygen will have leaked out and all you'll have left is nitrogen :tongue:
I'm being halfway serious... nitrogen inflation is a MAJOR scam. I understand some installers are providing it for free, but for someone to actually PAY to have it done is stupid. Nitrogen is used in aircraft because when a tire blows, it will not support combustion within the wheelwell.
The compression/temperature aspects of nitrogen are negligible under highway conditions. I've filled many scuba tanks with mixtures ranging from 10% to 50% oxygen and the only time there is a difference in adiabatic heating/compressibility is when helium is introduced into the mixture (helium is extremely hard to compress and generates a LOT of adiabatic heating).
I actually had a tire installer tell me that "Yes, air is 79% nitrogen, but all of the nitrogen stratifies into the upper atmosphere because it is lighter, leaving the 21% oxygen down here so we can breath, that's why they call it the stratosphere"
I asked him why they didn't call it the "nitrousphere" if that were true.
Complete lack of understanding about how gases work.
The air in an airliner IS outside air, compressed by the engine and fed into the cabin. NO additional oxygen is added... it's 21% oxygen at sea level and 21% at 40,000 feet, but at 40k, the pressure is too low to be survivable.
Probably correct, but again, under highway conditions, it's a non-issue.I don't have any personal experience with nitrogen in tires but have read that on the track, the pressure doesn't increase from heating like air does. remember that the racers measure their pressures down to .10 psi.
Yeah thats right. The race teams use nitrogen instead of atmosphere. because it doesn't build as much pressure and its build up is more predicatable than just straight atomosphere.I don't have any personal experience with nitrogen in tires but have read that on the track, the pressure doesn't increase from heating like air does. remember that the racers measure their pressures down to .10 psi.
hey! your not the guy I spoke with at the stealership a while back are you?hey. i get my air from the local gas station. it costs about 25 cents am i over paying? it would nice if it was like a vending machine. throw a quarter and make your selection. you got you cold air, hot air, luke warm air. foriegn air and domestic air. and even oceanic air. i was thinking about coming out with my own distribution air company. we would recommend you change your air every 3000 miles. if you use chinese air. everyone 200 miles. and jap aka: synthetic every 7000 miles. we guarentee our air will provide smoother ride or we will refund your money. for an extra charge we will put a special additive to your air that will give the bike added horsepower and low end torque. act now and receive a free valve cap and half off your next air change.
