1 - 9 of 9 Posts
Harbor Freight was about the only place I found one. Sears was out of stock when I went there.
For future needs you can also grind down a larger one to make it work.
Perpetual Motion
Doesn't matter, it won't hold it anyway. It'll still spin. You need to either pull the peg out as far as you can and coat the shaft with adhesive silicone or double sided tape. I used silicone and it's stayed put since.
Discussion Starter · #9 ·
yup, i used a few wraps of electrical tape and some 100% clear silicone as well. I'll check it tomorrow im assuming its not going anywhere.Also, its a 15 dollar part, not like i need to remove it at any point.
1 - 9 of 9 Posts
