G'day troops. I recently began the process of bring back to life a very nice 1992 ZX1100-C3 (ZZX1100) that has been sitting unoperated in a garage for more than 5 years. Obviously, lots of things require checking and some a bit of restoration (such as fuel lines, etc.) if the bike is to be brought back 'on-line, as it were. One of the subsystems I have addressed in my restorations is the ZX11 thermostat and housing assembly that perches on the right side of the frame near the top of the radiator. There seems to have been a slight coolant leak where that housing fastens to the frame, so I removed it and took it apart, thinking I'd replace the two 'O'-rings used on that thermostat housing, one being a 53.5 (Kawa Part # 92055-112) and a smaller 27.7 'O'-ring (Kawa Part # 92055-091). Both these 'O'-rings must be replaced when you change out the thermostat since they get compressed over time, leading to possible coolant leaks; but to my considerable consternation I found...after trying to order the smaller 'O'-ring (90255-091) from at least 6 other sources...that the 27.7 ring is unavailable (the orders all listed the ring as 'Unavailable from manufacturer; uncertain when it will be available'. WHAAAAAAT?!
That unhappy discovery has been quite perplexing, since the new thermostat is an important and necessary part of my 'restorative' work on this beautiful bike. Believe me, everyone I've tried (Babbitt's, CheapParts, RevZilla, CMS, GenuineKawasakiParts.com, etc., has all responded the same way!
The small 27.7 'O'-ring is also used as a sub-component (also listed as Kawa Part # 90255-091 'drain plug') on some Kawasaki front fork systems, so it's not just an isolated and otherwise inconsequential part! Surely this is a 'preventable' problem that deserves immediate resolution?!
At any rate, I am completely flummoxed by this status quo! Anyone out there have any helpful insights on sourcing out this small but important 'O'-ring, so I can get my thermostat back operating again? Thanks.😟
